gettin a gt turbo with standard turbo. thinkin of upgrading the turbo for more power. eg... for a hybrid turbo what is the diffference and what is everything needed for the upgrade?? rough price aswell
Hi mate
Welcome to the site.
Check out the section you just posted in -Turbo-Tech- and you will find a few articles that have already covered Hybrid Turbos.
They are well worth checking out.
Enjoy UKSC sensibly :D
Joz
quick answer
ECU
MANIFOLD
DECAT
EXHAUST
INJECTORS (Maybe)
SUSPENSION
BRAKES
IRRIDUM PLUGS
UPRATED HT LEADS
FMIC
plus thins i missed
Other answer use the search button this question pops up alot
where or can you buy a hybrid turbo kit or is there a tuning company that does it all for you. preferably in scotland
Guest Enzo
hey mate, im from scotland. where abouts in scotland are you based?
i can supply hybrid turbos,
you can check my subforum here.
click here for gt spec hybrid
also your in luck there is a guy i know that specialises in starlets, he has done for a good few years and stays in the central belt,
he can undertake any work you require, his company is called nippon r.
welcome to uksc ;)
im in falkirk. wouldnt be looking to do this until xmas time as money is a factor. where about are you based and what performance mods you done.
For a Hybrid, I'm sure the stock ECU is good (a fuel pressure regulator is perfectly fine)
Manifold isn't a must, although it'll help. A Hybrid will bolt straight onto a CT9 mani
Decat isn't needed either.
Injectors won't be needed until upwards of ~220bhp, about the max the average Hybrid will deliver safely
Suspension would be good
brakes would be good
Irridium plugs would be good
Uprated HT leads would be good
FMIC wouldn't be needed
Probably a relocated air filter too, although its optional tbh
All you *really* need is the turbo, and the fueling sorted. It'll be perfectly safe at that if its set up properly. The rest of it will just increase the power and/or make it more usable (handling/braking for example)
Dave
quick answer
ECU
MANIFOLD
DECAT
EXHAUST
INJECTORS (Maybe)
SUSPENSION
BRAKES
IRRIDUM PLUGS
UPRATED HT LEADS
FMIC
plus thins i missed
