low boost is set at 6psi where as hi boost is at 9psi mate
(info taken from a topic i found by searching in a good write up by enzo)
because i found a guide to set an actuator to, so should i set it between 6 and 9 psi or do it for 9 if u get what i mean lol.
Thanks
to be honest i would do away with the hi/ low boost and just run it on high boost all the time.
if your keeping the high low i think you set the actuator for the hi setting. im not 100% but it makes sense to do it that way.
