when at 4/5000 revs the car seems to shudder as if petrol isnt getting right through it happens most if pedal is too the floor.
what could this be is it normal?
whats your car and whatsyour set up?
scutch0 what is fuel cut exactly because that is it seems to be hapeneing.
dont know what boost im running just bout car and dont know anything about them but am learning.
It's like hitting a brick wall!
Get a boost gauge fitted that'll let you know what boost is being run.
You may need an HKS actuator to adjust the boost level till you can sort some electronic method out.
