starlet86 Posted June 17, 2008 Posted June 17, 2008 HiJust wanted to know how much boost i could run through standard intercooler on standard engine? All i have fitted is a BOV!Thanks Quote
Lee_EP82 Posted June 17, 2008 Posted June 17, 2008 Well i think the standard tmic is really good im running 1 bar and it really does the job well still. Not sure if it will be as efficient when i run 1.2 bar on a hybrid so then it would be a good idea to go for a FMIC.I have an uprated RX7 TMIC for sale if your interested. Quote
paul w Posted June 18, 2008 Posted June 18, 2008 The standard topmount is shite!If you must run a topmount then get an ARC topmount. If you are turning the boost up then increase the cooling as more heat is generated surprisingly enough! Standard topmount is not up to it IMO. Quote
starlet86 Posted July 5, 2008 Author Posted July 5, 2008 mmm now im confused as i have two different answers, would it be ok to run 0.9bar through the standard top mounted intercooler or not?!Thanks!! Quote
joe-ep91 Posted July 5, 2008 Posted July 5, 2008 I think its best not risk anything when it comes to cooling mate. Ive heard about 0.8 bar max on standard top mount, most people get front mounts when they run 0.8 bar +Hope this helps Quote
thunderpants Posted July 8, 2008 Posted July 8, 2008 any thing above fuel cut pressure on the top mount and after a bit of spirited driving it becomes way too warm through heat soak to be efficient and you end up geting a charge of hot air which aint no good. get your self either an rx7 topmount, arc topmount or a front mounted one. but be careful with the front mount as if you use too large an intercooler on a ct9 you will notice lag. unless you run a larger turbo to force more air through. Quote
