Where about / how many vacuum pipes are there in the engine bay?
I'm currently using the one coming from the throttle body for my dump valve,evc boost controller and boost gauge, I really dont like the look of all the t pieces!
Are any other vacuum pipes that I could use for my HKS evc?
  • 4 weeks later...
Theres a vacum line from the back of the intake manifold.
I take my boost gauge and boost controller readings from the rear of the intake manifold.The more t pieces youre running, the more likely you are to have a vacum leak, so keep them as direct as possible :)
try and plumb them into different sources, not all in the same place...and as ragger said, there is quite a few vacum pipes on the inlet mani.
