DavidAshton Posted June 28, 2008 Posted June 28, 2008 Went out for a rather spirited drive earlier after 2 mins of heavy breaking i was getting immense brake fade. Parked up to have a look at the brakes and the were mega hot, so hot they were smoking, burned my hand just touching the lug nuts. Anyway let the cool all seemed ok. Bit later on i start to get this mental squealing noise at low speeds but NOT when touching the brakes if i touch the brakes it stops. As i have no idea how brakes work is this just the pads worn and need replacing or is this something else? Its a ep91 n/a.Cheers Quote
Lee_EP82 Posted June 28, 2008 Posted June 28, 2008 I get the same on my GT, but i have new pads an disks to put on just waiting for my cusco bmcs and braided brake lines to arrrive before i make the change.But, id say it was possibly something to do with worn brake pads rubbing on the disks. Someone correct me if im wrong. Quote
montanajr Posted June 28, 2008 Posted June 28, 2008 Brake cover mate! Happened to me after a "spirited drive". The disc has a plate behind it that protects it, for some reason when they get hot the plate moves and scrapes against the disk. Just get something and push the plate back a bit to stop it from rubbing against the disc. Sorted Quote
Lee_EP82 Posted June 28, 2008 Posted June 28, 2008 I'l try that on mine tomorrow mate cheers.no rep points on here tho Quote
montanajr Posted June 28, 2008 Posted June 28, 2008 Haha yeah! Reread and you say a squealing sound, this sounds more like a metal scraping agaisnt metal sound! So don't hold your breath- I could be completely wrong! lol Quote
DavidAshton Posted June 29, 2008 Author Posted June 29, 2008 Haha yeah! Reread and you say a squealing sound, this sounds more like a metal scraping agaisnt metal sound! So don't hold your breath- I could be completely wrong! lolJust had a look at the brake covers and both were touching the disks so moved them back. Squeak went when i rolled in a straight line soon as i turned the wheels and used the brakes it was back again so now i dont no what it can be.......? Quote
montanajr Posted June 29, 2008 Posted June 29, 2008 Yeah if you drove the crap outta it and the brakes overheated you could've warped the discs as Jay suggested, so as they spin through the caliper they would vibrate a lot, but not really squeal I wouldn't have thought! At least you stopped the brake covers touching but if its only when you brake it must be something to do with the actual calipers/discs! Quote
DavidAshton Posted June 29, 2008 Author Posted June 29, 2008 Yeah first thing i thought was shit ive warped the disks but there is no vibrations or any difference in brake pedal or stearing. Dont have the tools to get all the front jacked up so i think ill go let the garage have a look in a bit. Didnt realise how shit my brakes were till yesterday, defo gonna be first think i upgrade when i get my glanza now. Thanks for all the advice so far. Quote
addz Posted August 6, 2008 Posted August 6, 2008 Did you get the squeak sorted?I changed my front disc's for 3g 10 grooved & mintex 1144's.Got a sqeak atm, not sure if its a bedding in squeak or a problem squeak?!Just done my brakes this morning. Quote
ecksjay Posted August 6, 2008 Posted August 6, 2008 may have been riding the brake if they overheated that quickly, even stock brakes should provide some stamina even during a spirited drive, especially if it was late (i.e cooler) and not on a boiling hot day.it took me a good 10mins to overheat mine on an airfield track day, on one of the worst airfields this side of the country for brakes (its absolutely devestating on tyres and brakes), however i was stamping on the brakes too early, and riding them somewhat. learnt after a while to stamp on them harder but later, gave them more of a chance to cool down (i.e wasn't actually on the brakes for so long), seemed to extend their life for much longer.either that or you may have sticking calipers as above (might have been staying on even after releasing the brake pedal). Quote
carswelk Posted September 23, 2008 Posted September 23, 2008 possibilty of retainer clips not holding the pads properly or problem with the shims? Quote
DavidAshton Posted September 23, 2008 Author Posted September 23, 2008 Sold this car a while back and got it sorted. It was the dust shield rubbing on the disks.Thanks for all the help aswell. Quote
Jozinobi Posted September 23, 2008 Posted September 23, 2008 Thanks for clearing that up David.I have a similar problem with my new brakes so now I know what to look for.CheersJoz Quote
