hi I've jus noticed im missing 2 ov the bolts wot hold my decat onto my turbo and I've been told by someone who works for toyota the bolts shud be welded 2 turbo from factory if u know wot i mean not good at explaning anyway mine has bolts heres a pic can any 1 help me get sum thanks
there should be studs in the turbo, the decat slides over the studs and nuts are tightend down to hold it in place. these always come loose due to heat the material expands and with the vibrations of the engine they work themselves loose
