Throw it away! It will help you in the long run to put some electronic management on instead. Thoses FCD kill engines! :D
The numbers relate to the voltage the FCD clamps the signal at. Lower nos = lower voltage clamp which gives higher fuel cut. Always best to start high on the FCD and work down if needed. Remember you should only adjust the FCD when tuning with a Wideband Lambda sensor, best left to an expert :D
Thats how they kill engines!
No fueling mods-FCD removing the safety cut off -turning up the boost -leaning the mixture and hey presto 1 fucked engine! :D
Not saying you have a fucked engine but if you aint got fueling mods it's only a matter of time.
uprated fuel pressure regulator,possibly injectors,some would say an uprated fuel pump but thats not needed.
If you're not upping the boost then why have an FCD fitted????
I suspect someone has already upped the boost before,then put it back to standard before they sold it on. ^_^
can you tell me what you mean by fueling mods
plus i have not up't my boost
do you have a boost gauge so you can tell exactly what boot you are running- because when you say you havnt uped the boost what is it actually running at the moment?
