abbott Posted September 12, 2008 Posted September 12, 2008 As above can any one help with specing me a turbo?because the cr level is low comp i am going to have a lag issue, my aim is to get 280bhp+. My engine has been built to take high boost and want somethink which is going to work well. I will be changing manifold, turbo, intercooler, exhaust.here is my set up at the mo1.5bar boost268bhp218 torque211 whp4E-FTE CR 7.5:1wossner forged pistons wossner forged rods Fully balance bottom end Gas flowed and polished head Ported and polished inlet manifold 2mm head gasketLight weight Crank pully Custom manifold Custon pipework Custom front mount intercooler Custom oil cooler Custom oil catch tank Custom braided oil and clutch linesCustom turbo water lines Custom Front exit exhaust (heat wrapped)HKS GT25/30 roller bearing turbo HKS air filter HKS ssqv blow off valve HKS actuatorGreddy emanage ultimate with main, injector and ignition harnessesGreddy emanage 3bar pressure sensorGreddy knock sensor adaptorGreddy Profec B boost controller Sard 550cc injectors Sard Fuel Pressure Regulator Walbro Uprated Fuel Pump Magnecor 8.5mm leads NGK Iridium plugs any help will be appreciated Quote
RobSR Posted September 12, 2008 Posted September 12, 2008 TD05-14B? dunno what housing sizes they do it in tho...think its an 8cm..?!? May be a little laggy though... but should make over 300 horse..can get it both in internal wastegate or for it to work with an external one.you could even go down to a TD04H-15G/16T/19T all of which should flow around the 300 horse mark. Quote
ecksjay Posted September 12, 2008 Posted September 12, 2008 do you want lag or is that just a by product of what the engine spec is?I can happily find you something suitable mate, it just depends what you actually want from the engine. Quote
abbott Posted September 12, 2008 Author Posted September 12, 2008 do you want lag or is that just a by product of what the engine spec is?I can happily find you something suitable mate, it just depends what you actually want from the engine. mate pm me your number and i will have a chat. i want 280bhp+ dont mind some lag but not stupid amount Quote
StarletRick Posted September 12, 2008 Posted September 12, 2008 HKS GTRS would be a nice little turbo for that application. Quote
Guest Enzo Posted September 13, 2008 Posted September 13, 2008 would be good to know what air the engine can push out,that way you could find the perfect right turbo for your aplication buy looking at the different compressor maps and cfm ratings of different turbosi still cant understand how to calculate it perfectly the turbo that has the right efficiently range for your engine,to read up on what im on about have a look at this, perfect for finding the right turbo for your aplicationif you can find out how much your air can push out and can read a compressor map its the only way to get a concrete firm choice ideal for your spec, and not on recomendation. Quote
ecksjay Posted September 13, 2008 Posted September 13, 2008 GTRS would be FAR too laggy, they're laggy on SR's rick, hence why they're rated at 400bhp, they do come with some lag.He's along the right lines with a GT2530, although they're an older design so i believe they're a little mismatched (intake/exhaust), so something along that sort of line but with a better efficiency curve should help.I'll have a look and see whats available for good money at the moment Quote
StarboZo Posted September 13, 2008 Posted September 13, 2008 Td04 exhaust side mated to td05 this would see good spool with 280 + I would have thought!lol wrong login...Starbogt Quote
