CraGle Posted September 16, 2008 Posted September 16, 2008 Ill try and be as descriptive as possible without sounding like a complete noob.Ok i Think i have a problemDriving along from first. 3 lil green lights, changes gear, into 2nd all 3 lights come on before i hit 5k rpm , and the car jolts, like a savage stamp on the accelorator, and the engine light comes n, quickly changes into 3rd think wtf have i done, i hope i havent killed it.Anyhelp would be great.Currently got the Cat on for mot, FCD, HKS ssqbv full blitz system, standard turbo and internals. Thanks in advance Quote
SiCaln Posted September 17, 2008 Posted September 17, 2008 sounds like fuel cut, means u are running too much boost - but should happen if u have fcd Quote
CraGle Posted September 17, 2008 Author Posted September 17, 2008 running standard boost, i noticed it was more of a pop and jolt in 3rd, which means plugs possiblely???fcd. :/ like i say i have 1 installed.I dont really know. Quote
paul w Posted September 17, 2008 Posted September 17, 2008 Yes but is it actually wired in correctly?? Seems to me it's not Standard boost yet you have an FCD fitted...... Maybe you ain't got one at all Quote
CraGle Posted September 17, 2008 Author Posted September 17, 2008 the FCD, is fitted to the side of the ecu ???? Quote
CraGle Posted September 22, 2008 Author Posted September 22, 2008 4 dead plugs, all changed, and still jolting fcd is set at 8? is this correct? Quote
Guest Enzo Posted September 22, 2008 Posted September 22, 2008 i have never used an fcd so couldent saydo you have a boost guage? Quote
CraGle Posted September 22, 2008 Author Posted September 22, 2008 i do, it goes straight round to full pressure on idle :/ which i dont think is right Quote
CraGle Posted October 5, 2008 Author Posted October 5, 2008 bump still got problems... car now sounds like its limiting at 3000rpm and wont go no further!!!heeeeeeelp plz Quote
ecksjay Posted October 5, 2008 Posted October 5, 2008 remove the fcd.fuel cut is there for a reason, if you dont have any fuel control, you dont need or want a fcd, as you'll only experience problems.if you've been twatting it off fuel cut lots then it wont have done it any good. it may well be wired incorrectly so best to remove and then see how she feels, it'll then bounce off fuel cut at 0.93bar (give or take, depending on boost gauge accuracy) and then you'll know it was just that (the fcd may be malfunctioning or some of the wires may have become damaged, such as poor wire splicing etc). Quote
