turbodreams Posted September 17, 2008 Posted September 17, 2008 What spark plugs are recommended for a 96 glanza. Quote
Glanza_cl Posted September 17, 2008 Posted September 17, 2008 What spark plugs are recommended for a 96 glanza.ngk iridium are good, but there are quite a few to choose from- heat range 7-8 would be fine Quote
StarletRick Posted September 17, 2008 Posted September 17, 2008 if youre running a stockish setup you wont need to waste money on iridiums. just get some normal grade 8's Quote
turbodreams Posted September 17, 2008 Author Posted September 17, 2008 cheers lads, your help is much appreciated! Quote
chooch HELP Posted September 28, 2008 Posted September 28, 2008 get ngk R BCPR6ES in it if its stock there cheap as fuck and do the job i use these and just change them every 2-3k Quote
