AlexGTAdv Posted October 9, 2008 Share Posted October 9, 2008 I have aquired an HKS actuator and was having a look on the box and it sais its for an EP82 89-92. As some of you know mine is a 95! I thought all GT's had the CT9A so what is the difference? Will it go on my car??? Cheers guys Quote Link to post Share on other sites
keirz Posted October 9, 2008 Share Posted October 9, 2008 just have a look at the arm on the actuator. some have a hole on the end and some have a pin. look at your wastegate arm on your turbo and see if it requires a pin or hole.easy as that mate. they are identical other than that. Quote Link to post Share on other sites
AlexGTAdv Posted October 9, 2008 Author Share Posted October 9, 2008 Cheers for that i'll check it out. Quote Link to post Share on other sites
Tellyboy Posted October 13, 2008 Share Posted October 13, 2008 Cheers for that ;) i'll check it out.Alex, your boost creep. I suspect you have a restriction in the feed to the actuator, meaning it can't open far enough to vent the exhaust. Either that or it's fed from the wrong place. the feed to the Blitz solenoid should be straight off the turbo. Quote Link to post Share on other sites
