Glanza dash Can i put the glanza dash with the rev gauge straight in to the normal ep where it originally just had speed, fuel and temp gauges. is it a straight swap/ plug in or is some strange wiring involved?
Needs rewired Gav, the plugs will be different and certain items will not function if the wiring and sensors are not there to support them (for example the rev counter will need a signal from the ecu to function correctly).
Not impossible but a right pain in the ass to do right.
Jay
damn! Thats that so
Cheers anyway
Paseo or SR clocks would be easier in a UK spec N/A. (Assuming that's what you've got because these are the same clocks as mine with just the speed/temp/fuel).
There are extra things like the boost lights on the Glanza one that you wont need to use, so it's much simpler to go for SR (black) or Paseo (white) clocks.
Paseo dials would be better :p 7krpm on clock which is enough for N/A as they only rev to 6.2k took me bout 2 hours to take old ones out rewire plugs and put new ones in.
