4efte_ryan Posted October 25, 2008 Posted October 25, 2008 hi guys i have a idle problem on my glanza...right when i first start the car it sits at around 1500rpm nd after about 5 mins it finallly drops to 1000rpm,when im driving the car when i stop and let it idle it can sit around 1500rpm and sometimes 2000rpm but varies and finally drops usually once the fan cuts in and drops back down after that but still takes quite a while.. i have already adjusted the idle contol screw down but hasnt made much difference. does anyone have any idea what the problem could be???? cheers ryan Quote
andy.i Posted October 25, 2008 Posted October 25, 2008 when i go to work in the morning, bout 4.30am it usually idles pretty high but settle down, maybe just trying to warm up th engine a bit? Quote
ste91 Posted October 25, 2008 Posted October 25, 2008 Do you have things on like wipers/rear windor demister/heaters/lights/etc...? Quote
4efte_ryan Posted October 25, 2008 Author Posted October 25, 2008 no it happens even if nothing is on, there is deffinatly a problem, as i said it can sit at 2000rpm when car has been driven around for quite a few mins then sits at 1500rpm and then 1000rpm maybe idle control valve????? Quote
