turbodreams Posted November 5, 2008 Posted November 5, 2008 hey can someone show me what the Rotor Arm And Distributor Cap for the glanza look like? Quote
turbodreams Posted November 5, 2008 Author Posted November 5, 2008 Oh and, i presume the Distributor is different from the distributor cap? I was told my distributor (cant remember if i misheard him he may have said distributor cap) was worn? Which could it have been if they are different?So is the distributor cap different from a distributor cap, or is it the same name for the one thing? And if they are different which is the more likely to be worn. Quote
paul w Posted November 5, 2008 Posted November 5, 2008 http://www.ukstarletclub.com/forums/index....showtopic=11334 Quote
turbodreams Posted November 5, 2008 Author Posted November 5, 2008 thanks mate, what about the differences between distributor and distributor cap? Or is there even a difference? Quote
addz Posted November 5, 2008 Posted November 5, 2008 From my knowledge the rotor arm is the red small component that sits in the distributor cap.The Distributor cap is the black unit which has 5x holes for the spark plug leads.Hope this helps Quote
Asad Posted November 5, 2008 Posted November 5, 2008 Distributor is the name of the unit as a whole.....?????buy new from sam mate dont cost that much and a used one will be that, used Quote
ste91 Posted November 5, 2008 Posted November 5, 2008 I have a brand new (still in the box) 4EFTE rotor arm for sale if you need it, I bought it thinking the 4EFE/4EFTE rotor arm/dizzy caps were the same but they aren't. Also have an NGK king lead as the 4EFE only needs the four leads. Quote
