GT Phayer Posted November 6, 2008 Posted November 6, 2008 was just wondering if any 1 had any pictures of there turbo timer wired up.im a bit confued were the wires go.thanks. Quote
cam13T Posted November 7, 2008 Posted November 7, 2008 Mate your best off getting one with a harness made for your model so it is plug and play, makes installing easy as and if you want to remove it for some reason you dont have split wires. Quote
GT Phayer Posted November 8, 2008 Author Posted November 8, 2008 i have mate i got a blitz harness for a ep82 but i got a sard turbo time it all fits its just i got a wire from the turbo timer left over Quote
GT Phayer Posted November 8, 2008 Author Posted November 8, 2008 i have this wire left over,does any 1 no wah its for ? Quote
cam13T Posted November 8, 2008 Posted November 8, 2008 Yes i got a blitz harness too, on the small 3-pin plug you are pointing to 1 wire (purple) goes to the handbrake, and the other orange and white i didn't use.Just tap into the handbrake cable in the grey plug under the ashtray section im pretty sure its (Yellow/red stripe.) So when the handbrake is realeased during a countdown it will automatically shut the engine off. Quote
GT Phayer Posted November 15, 2008 Author Posted November 15, 2008 would the two wires at the bottom join togeva ? Quote
GT Phayer Posted November 23, 2008 Author Posted November 23, 2008 would the timer still work woth this wire arrowed off ? Quote
