nic1.3 Posted November 18, 2008 Author Posted November 18, 2008 It shouldn't make any difference the ep82 won't weigh anything more at the back I doubt, at the front its maybe slightly heavier but still wouldn't make much difference.I'll be disappointed if the koni's have started leaking because I was thinking about getting a set instead of my cusco coilovers, how was the ride on them before this?well i did the bounce test and there's little to no bounce at the rear, well none I can see anyway.also the ride quality was always good in them but the change in ride quality could be down to the tire pressure im using (I've set tire pressure a good bit higher to see what difference it would make to the car), I mite rip out the rear's and adjust them alittle softer to see if it improves things. Quote
Asad Posted November 18, 2008 Posted November 18, 2008 u sorted then...no bounce = good shockerover inflation can cause the tyre to wear by the way ure not trying to copy top gear are you? with the salt plains? Quote
