its not that complicated, saying that i have never fitted one so im really not the best to advise,
aparently the fitting is not the hard bit but setting up the pressure is
maybe someone who has fitted one could coment
i have just bought the same one from mc gill motorsports, really good quality and apparently easy to set up, im still waiting to get it fitted s this is usefull info for me to.
  • 3 weeks later...
Hi,
An adjustable reg would need to be set on a rolling road. I would not recommend setting it by feel, recommended setting or anything else. Even a few psi out and you will burn through plugs or worse under heavy use/load. These should only be fitted to cars running a fair bit more boost and they do not offer any "bolt on" performace like a full exhaust system would.
David
