Dan Evans Posted December 16, 2008 Posted December 16, 2008 hello to all, i read u can de-restrict 1st and 2nd gear by basicly moving a couple of pipes, so i tried it and i love it, only thing tho that is I've lost the lo/hi button, apparently u can pipe it in a certain way to be able to use the button. i have tried it a couple of ways but it still wont work??i just dont want to put my foot down in 1st & 2nd and wheel spin all the time, but it is good to have.any ideas or pictures????????? Quote
WallaceGlanza Posted December 16, 2008 Posted December 16, 2008 If you derestrict it you remove the hi/lo solenoid too. So the way you've done it will be correct. Quote
DavidAshton Posted December 16, 2008 Posted December 16, 2008 I dont get what your saying you want it de restricted but still use the hi/lo button? I have mine hi/lo piped in with a toytuning actuator, no restriction in 1st and 2nd but it has lo boost of 0.6 bar and hi of 0.8 bar. Only way I think u can have Hi/Lo button and no 1st, 2nd restriction. Quote
Dan Evans Posted December 16, 2008 Author Posted December 16, 2008 yeah i am wanting to de restrict 1st & 2nd gear but only doing it by pushing the button, so i want to use lo boost in all gears, then flick the switch and use hi boost in all gears??? Quote
DavidAshton Posted December 16, 2008 Posted December 16, 2008 Only way i can think of doing it is an aftermarket actuator. Dont know if its supposed to work but on mine i have no 1st 2nd gear restriction just full lo and hi boost in all gears. I guess its because its piped in differently. Quote
