poknong Posted December 18, 2008 Posted December 18, 2008 Hi Guys, Would anyone know what the standard boost pressure, oil pressure, exhaust temp reading for the 4efte (idling or otherwise)? Thanks a lot! Quote
Kennedy Posted December 18, 2008 Posted December 18, 2008 Well I havent changed my boost settings yet and i get 0.75bar on my turbo.As for the others i don't know lol Quote
WallaceGlanza Posted December 18, 2008 Posted December 18, 2008 Well I havent changed my boost settings yet and i get 0.75bar on my turbo.As for the others i don't know lolThats higher than standard.Boost is 0.4bar on lo and 0.6bar on hi.Oil pressure is about 4.5 -5bar on cold idle, 1.5bar hot idle, 3-4 bar wot. But will vary depending on the oil.EGT no idea for a standard setup but generally the max you ever want to see is around 700 degrees c. Quote
Kennedy Posted December 19, 2008 Posted December 19, 2008 Thats higher than standard.Hmm don't think its been modded yet apart from the EBC (which isnt setup yet).Unless its just the EBC displaying the wrong boost..not got a decent gauge yet so not sure. Quote
WallaceGlanza Posted December 19, 2008 Posted December 19, 2008 If you have any sort of exhaust or air filter upgrade it will make the turbo breathe easier basically and increase the boost it runs. Quote
BoostJunkie Posted December 19, 2008 Posted December 19, 2008 Thats higher than standard.Boost is 0.4bar on lo and 0.6bar on hi.Oil pressure is about 4.5 -5bar on cold idle, 1.5bar hot idle, 3-4 bar wot. But will vary depending on the oil.EGT no idea for a standard setup but generally the max you ever want to see is around 700 degrees c.is boost not 0.6 on low and 0.7-0.75 on high ? Quote
AlexGTAdv Posted December 19, 2008 Posted December 19, 2008 is boost not 0.6 on low and 0.7-0.75 on high ?Low should be about 0.4-0.5 and some people get on high 0.6- 0.7, like the man said it depends on wot sort of mods you have. On mine when i had a standard exhaust apart from a back box and an air filter on high it would only boost to 0.5! but after i put my full system on and decat, it hits fuel cut!! Quote
