Hi there,
I'm new to this board, was registered in the past, but somehow i was deleted from the database.
Anyway, live in the Netherlands. Have (had) a EP71 an 3drs AE86 and a EP8 non turbo B)
EP71 was a project with a 4AGE engine in it. Had a lot of fun on the tracks. I've been racing as amateur for nearly 4 years, but blown the engine up in octobre.
Now i'm building up a new shell up with an Blacktop engine.
AE86 is a long term rebuild project.
And my EP8 is just a temporary daily driver :) (not sure about doing a fte swap B))
I bought a new shell and this is for 95% rustfree ^_^
This pic is taken a while ago when i fitted the cage into it.
Still feed to drop the blacktop into it.
Short speclist of my old ep7 that's going to be swapped on this shell.
- Turbo S Bodykit
- Sparco Corsa Race seats
- 15 inch OZ Ultraleggera
- yet to come Volk Racing TE 37
- TRD Coilovers 55mm (front) -55 (rear) mm lowered
- Cusco Camberplates and Pillowball mounts set
- 18mm GAB Stabilisatorstang front side
- EP82 Whiteline Adjustable rear Swaybar (adjusted to fit the EP71)
- Cusco pillowball adj panhard rod
- Cusco front Lower arm bar
- Cusco Carbon strutbars front and rear
- "Small" bigbrake kit: 260mm discs in stead of the standard 226mm discs.
- Twin pods brake calipers
- Brake discs are Group N Formel performance disc with holes drilled within it and i use Ferodo DS2500 brake pads.
- Goodridge brakelines with teflon coating
oh yeah... Blacktop engine with T3 Velocity Stacks... and with a TOM's Tec Ecu ^_^
I do a lot of importing myself so this is how i got most of the parts :p
Welcome to UKSC
3 amazing motors dude hats off to you!!
Loving the pic of your track beast on the track looks awsome!!
Good luck with the builds, love the look of your EP80 you know you want to FTE it ^_^
Some pics of the toys i'm going to fit into the EP7 racer
Special Cluster.
Toms tec 2 ecu for my blacktop engine
VTI Radiatior
New Quaife LSD unit ;) Mechanical not clutchplated.
And my engine ;)
Still have a lot to do but no spare time at all.
Hope to get in running in the spring 2009 ;)
