pick Posted December 29, 2008 Posted December 29, 2008 im having an fcd fitted and hks adjustable actuator to handle slightly more boost nothing to kill it hopefully was thinkin bout getting it rolling roaded and re-mapped for fueling reasons but heard the standard ecu is non accessible and cannot be re-mapped is this true ??? many thnx for replies Quote
Sparky Posted December 29, 2008 Posted December 29, 2008 You will need at least a Apexi Neo fuel computer or SAFC something along those lines or get a piggy back ECU like a GReddy Emanage blue for even more control.Would be better off getting a Fuel Pressure Regulator and one of the above and getting it tuned then ;) Quote
pick Posted December 29, 2008 Author Posted December 29, 2008 what or how is the best way to set up the fuel pressure reg until i can afford to get better management n rolling road it ??? ;) Quote
Sparky Posted December 29, 2008 Posted December 29, 2008 It NEEDS to be set up on the rollers mate, every car differs Quote
Glanza_Ragger Posted December 29, 2008 Posted December 29, 2008 You can play it safe and run it at about 3bar temporary untill you get it mapped.I never suggest people fitting FCD's , there THE fastest way to kill an engine.And it would definately be an expensive mistake for you to make, ditch the idea of upping the boost past fuel cut untill you have proper management.Otherwise you will regret it.IF you really have to run past fuel cut for some unknown reason without proper fuel management, run either a greddy or jam BCC. throw the hks version in the bin, there shat Quote
pick Posted December 30, 2008 Author Posted December 30, 2008 What would i need from this list?????? Greddy E-Manage Blue Piggyback ECU Main Unit - £240 DeliveredGreddy E-Manage Blue Injector Harness - £43 DeliveredGreddy E-Manage Blue Ignition Harness - £45 DeliveredGreddy E-Manage Blue 3bar Pressure Sensor - £90 Delivered Greddy E-Manage Blue 3bar Pressure Sensor Harness - £35 DeliveredGreddy E-Manage Blue Knock Signal Adaptor - £35 DeliveredGreddy Emanage Support Tool Kit - £90 Deliveredseriously considering it!!!!! Quote
