snails ep91 Posted January 12, 2009 Share Posted January 12, 2009 right about 2 months ago i fitted a new clutch at work with my boss. well he did it mostly i watched lol. anyways im having troubles its a exedy standard replacement however since doing it ive gt a really harsh pedal feel and now the clutch pedal almost makes a rubbing sound and squeks and it is the pedal making tht sound, but have no idea what is doing it so if anyone could help?also first gear makes a bad whining sound at low revs at biting point but also makes a horrible "burning plastic" sort of smell( only noticable when parking and out of car) but is a right pain in the arse as new clutch and stuff and expected it to be fine and just doesnt feel right. doesnt slip or anything but im comparing this to a worn clutch before so...also another big problem is the gear change feel is soo clunky and horrible its just wrong. i also have real problems changing from second to third where it wont go into third. have to bring it back then put it back in. is gettin very bad.i know its a lot of writing but my mot is coming up and reall need to sort these things out before handalso its a uk n/aany help appreciatedcheerssam Quote Link to post Share on other sites
Toby@ToyTuning.com Posted January 12, 2009 Share Posted January 12, 2009 Hi Sam,Was the release bearing changed? And was the flywheel skimmed or did he not think it needed doing?Let us know when you can.T Quote Link to post Share on other sites
snails ep91 Posted January 12, 2009 Author Share Posted January 12, 2009 hi thanks for the reply.yer the release bearing was changed, brand new one but no the flywheel was not skimmed. what would this do. this is my first car and im still learning but i also think theres a problem with the pedal, but was no problem with it before i dont know just feels and sounds from clutch pedal however the harshness must be something else i thought.cheerssam Quote Link to post Share on other sites
BAZ2CRAZY Posted January 13, 2009 Share Posted January 13, 2009 Sorry to interupt, but the clutch mounts the flywheel and the friction plates are compressed onto the flywheel giving drive? is that right? Mitch Quote Link to post Share on other sites
