228whp ep91 Posted January 15, 2009 Posted January 15, 2009 i have just been quoted around 3 grand for a 4efte engine conversion with forged internals fast road cams with a hybrid ct9 turbo and a mapped ecu does this sound fair o you lot or is it easier for me to build the engine and fit it? Quote
SiCaln Posted January 15, 2009 Posted January 15, 2009 that stupidly overpriced unless it inc all parts Quote
Toby@ToyTuning.com Posted January 15, 2009 Posted January 15, 2009 What is the full spec list they have offered, who is it and what expereince do they have the 4efte?We charge £2350.00 Inc VAT for a full forged engine only, that's drive in drive out. That doesn't include cams, management, turbo so sounds quite cheap but let us know on the above. With something like a forged engine it's crucial you don't skimp on costs and use the right people but this doesn't mean they are not up for the job.Thanks,Toby Quote
228whp ep91 Posted January 15, 2009 Author Posted January 15, 2009 i want something to play with,i have just bought a starlet 4efe Quote
Toby@ToyTuning.com Posted January 15, 2009 Posted January 15, 2009 that stupidly overpriced unless it inc all partsI think he means it comes with those parts, taken from our workshop page this is what you can do with us:"Complete Newly Rebuilt Forged 4EFTE Engines. All engines supplied to the following specification, options available on request:Wiseco Racing Low/Normal Compression 74.5mm Pistons Wiseco Racing Piston Rings/Pins Scat Forged Conrods with ARP 2000 Connecting Bolts Uprated Bi-Metal Head Gasket (Thickness Pending CR's) New Cambelt/Tensioner/Idler Kit New OEM Toyota Head Bolts New OEM Toyota Complete Engine Gasket Set New OEM Toyota Oil Seals New OEM Toyota Water Pump New OEM Toyota Oil Pump New OEM Toyota Coolant + Flush New OEM Toyota Gearbox Oil New OEM Toyota Valve Stem Seals Uprated ACL Main End Bearings Uprated ACL Conrod Bearings/Shells Uprated ACL Thrust Washers Crank Reground (if needed) Full Bottom End Rebuild Block Professionally Rebored/Honed Head Stripped/Cleaned/Re-Shimmed Block Cleaned and Painted Rocker Cover Cleaned and Painted Suitable For Up To 400hp With Correct Supporting Mods Pricing:£2350.00 Inc VAT - This service is available for those that would like to drop there car off with the work carried out at our workshop. Price includes labour for removal of your engine, rebuilding/forging, re-fitting of forged engine and all new ancillaries. Not an engine exchange basis, work is carried out on your own engine and is based on your engine being a stock serviceable example. We will require your car for 2-3 weeks. If you would like to purchase a forged engine only please see below.£1950.00 Inc VAT - This is for a forged engine only with all ancillaries as listed above. This is for international customers or those who would prefer to remove and install there own engine. We will arrange a palette delivery for your old serviceable engine once we receive payment. On receipt of your old engine and inspection we will return a fully forged engine via palette delivery ready to go. Please check for availability.Optional Extras - POA:5E Conversions Port/Polished/Gas Flowed Cylinder Head Re-profiled Cams/Billet Cams Cruise Valve Springs/Solid Lifters ACL Uprated Bearings Lightened/Balanced/Knife Edged Crank Baffled Oil Sump Block De-burring PE Kevlar Super Strong Cambelt ARP Head Studs ARP Main Bearing Bolts Light Weight Power Steering/Water Pump/Alternator/Crank Pulleys + More! As well as 5E conversions we can also carry out 4efte transplants into the NA Starlets, Paseos, Cynos, Sera etc. Please note we also cover normal rebuilds using OEM parts if needed depending on your requirements. If you've snapped a conrod or simply fried a piston ring then get in touch!" Quote
Toby@ToyTuning.com Posted January 15, 2009 Posted January 15, 2009 i want something to play with,i have just bought a starlet 4efeWe need to know what that includes, does it come with the engine, do you need to get a 4efte engine, does it come with the forged parts or do you need to buy these?Let us know it's very hard to tell from the info Quote
228whp ep91 Posted January 15, 2009 Author Posted January 15, 2009 its with a company called nitro perfomance in chesterfield, hes a friend of mine so its mates rates and as far as i am aware they are pretty savvy with the fte conversions, it was for me to find an fte engine they wil blueprint it and recon it with forged pistons stainless rods fast cams,a remap and hybrid the ct9 with an fmic Quote
Toby@ToyTuning.com Posted January 15, 2009 Posted January 15, 2009 its with a company called nitro perfomance in chesterfield, hes a friend of mine so its mates rates and as far as i am aware they are pretty savvy with the fte conversions, it was for me to find an fte engine they wil blueprint it and recon it with forged pistons stainless rods fast cams,a remap and hybrid the ct9 with an fmicIdeally you need to get a full break down of everything, do they fit things like new oil pump, new water pump, new head bolts, new gaskets/seals etc Do you know how many they have done? Not putting them down at all have no idea who they are but you need to get ALL the details before commiting, a lot of people promise the world and can't deliver just saying this for your own benefit and nothing else as you could end up spending a lot more money in the long run.T Quote
Guest Enzo Posted January 15, 2009 Posted January 15, 2009 first off whats your powergoals mate, how much power are you wanting to produce? Quote
228whp ep91 Posted January 15, 2009 Author Posted January 15, 2009 o ye and at the moment my starlet is just a 1.3 na Quote
SiCaln Posted January 15, 2009 Posted January 15, 2009 also what rods, pistons etc are they gna use? Quote
228whp ep91 Posted January 15, 2009 Author Posted January 15, 2009 thanx for the info guys,well as much as i can put down without comprimising handling etc too much,thelad said out of that conversion im looking at 220 bhp Quote
228whp ep91 Posted January 15, 2009 Author Posted January 15, 2009 they didnt go into great detail.toy tuing looks like a rough idea of what im after.@toytuning how much to transplantant fe for an fte Quote
Toby@ToyTuning.com Posted January 15, 2009 Posted January 15, 2009 they didnt go into great detail.toy tuing looks like a rough idea of what im after.@toytuning how much to transplantant fe for an fteYeah you just need more info from them really. We would charge as above, do you really need to go all out? Why don't you just do a conversion with a stock 4efte, get used to it and go from there?Labour wise we would charge £1000.00 Inc VAT for a conversion exc parts, it's not that hard but the loom takes at least half a day to splice if you get a EP82 4efte engine. If you get a EP91 Glanza engine then this time is reduced as you don't have to splice the entire loom with the old one. Overall not hard just takes some time to do.If you want to discuss further send an email to toytuning@toytuning.com or give us a call on 0844 5610910, we are not open until next week thoguh but more than happy to offer our advice even if you don't use us, I converted a SR around 6 years ago for myself and sold it to Envy Performance in the end so have lots of info.For a basic conversion you will need:4EFTEwiring loomecustarteralternatorcoil & igniterintercoolergearboxclutchflywheelYou could use the stock drivetrain which some do do but won't last forever as it's a lot more stress than the stock 4e NA.Hope this helps.T Quote
228whp ep91 Posted January 15, 2009 Author Posted January 15, 2009 hi,well i have an 98 4efte complete with box 48 000 had it in my garage since i was about 14 its was my sisters,so all i rele need is a loom an ecu and an fmic then im ready to go? all i was thinking is that i can forge an engine whilst its out instead of putting it in and taking it out and putting it in which i doubt i could do without making a mess,was also looking to fit an lsd,left that off the list haha but i wanna blow my budget on performance and leave it as a sleeper and then modd the exterior wen i catch the bug haha Quote
Callan Posted January 17, 2009 Posted January 17, 2009 220 bhp is possible for as little as £1500 for parts from a stock 4efte on stock internals and management4efte conversion isnt that hard imo, youve had a 1998' 4efte for 6 years wtf??also, stock internals are fine for 220+ bhp, im going to run 1.2 bar with a td04l on stock internals and management, 240-260bhp in reach Quote
228whp ep91 Posted January 18, 2009 Author Posted January 18, 2009 220 bhp is possible for as little as £1500 for parts from a stock 4efte on stock internals and management4efte conversion isnt that hard imo, youve had a 1998' 4efte for 6 years wtf??also, stock internals are fine for 220+ bhp, im going to run 1.2 bar with a td04l on stock internals and management, 240-260bhp in reachmy sister and her husband own an engine supply shop,(engine specialist) and its been in my garage well ages years i v asked her several times nicely if i can av it and she just warming to the idea but bourkey can get pretty mint engines so im prob just gonna go thru him as he has like a kit Quote
Guest Enzo Posted January 18, 2009 Posted January 18, 2009 sweet, can your old man get a hold of any JDM 5e-fhe's.. found in eather the toyota cynos or toyota sera??? Quote
228whp ep91 Posted January 18, 2009 Author Posted January 18, 2009 ill ask him, he has alot of jap engines as i wanted to mid mount a 2jz-gte in a starletbut i think that is a bit overkill haha Quote
