iamlegend Posted January 19, 2009 Posted January 19, 2009 just advice on what to do becouse i havent got a clue lol Quote
Callan Posted January 19, 2009 Posted January 19, 2009 il give you a tinkle on Msn mate, you could of just asked on there lol Quote
Steve GT Posted January 19, 2009 Posted January 19, 2009 did you buy it new???i got a new blitz one the instructions were in japanese but was easy to woirk out using the picsmost of its just replacing pipes then fitting them and mounting the valve Quote
Glanza_cl Posted January 19, 2009 Posted January 19, 2009 it's so easy if it comes with all the needed parts, just a basic swop take out the standard reserc connect up the new one Quote
andy.i Posted January 19, 2009 Posted January 19, 2009 ^^forgot to ask glanzacl did that hose fit ok!? (sorry bit off topic) Quote
Glanza_cl Posted January 19, 2009 Posted January 19, 2009 yeah worked a treat cheers again, perfet fit Quote
iamlegend Posted January 19, 2009 Author Posted January 19, 2009 i just got the dumpvalve its self,http://cgi.ebay.co.uk/1-25mm-SILICONE-DUMP...%3A1|240%3A1318i bought this here, so should all fit i hope, shouldnt it. (cheers cal)i got the hks ssqv valve Quote
Callan Posted January 19, 2009 Posted January 19, 2009 dude, made a bit of a cock up, if you see the hks above that glanza cl has posted, thats the stock pipe and the hks, i didnt think the hks would fit it but obviously it does, sorry bout that, you dont need the 25mm pipe then, you can go fit it now even with out that pipeCal Quote
iamlegend Posted January 19, 2009 Author Posted January 19, 2009 yeah worked a treat cheers again, perfet fit i only got the dumpvalve by its self, did you just use your stock pipes to fit it then? Quote
Callan Posted January 19, 2009 Posted January 19, 2009 see this one here^^^^ he has his head screwed on proper!!! mesh the inlet of turbo, block up dv!!! ftw Quote
Callan Posted January 19, 2009 Posted January 19, 2009 Your incredibly wrong sir, why waste the £130.....lol Quote
Glanza_cl Posted January 19, 2009 Posted January 19, 2009 so you dont have to pay £500 for a new turbo when you suck up a small bird lmao Quote
Sparky Posted January 19, 2009 Posted January 19, 2009 What would you block the pipes with?Might try it on the weekend Quote
Glanza_cl Posted January 19, 2009 Posted January 19, 2009 i no was just being sarcastic lol, it's not to bad if the turbo was top mounted as dirt wouldn't be as prone to being sucked into the turbo but being located down closer to the floor it's inevitable really, no harm in a filter better to be safe then sorry imo Quote
Glanza_cl Posted January 19, 2009 Posted January 19, 2009 What would you block the pipes with?Might try it on the weekend the small pipes a screw, the top pipe just get a rocker cover breather or oil catch can.the hks full kits come with an adapter which you can see in the pic i posted up Quote
Sparky Posted January 19, 2009 Posted January 19, 2009 What about the bottom pipe that goes to the intercooler piping? Quote
Glanza_cl Posted January 19, 2009 Posted January 19, 2009 which bit? if you keep the tmic the bov has to connect to the bov port on the tmic?i'm not 100% what pipe you mean lolooo do you mean to run no bov?if so just find a big bolt lol it's only 25mm wide i think or get a fmic lol Quote
Sparky Posted January 19, 2009 Posted January 19, 2009 Yea i mean no BOV lolMight do that tomorrow then, got a Blitz SUS but its where the airbox would be, should be OK until I can get a relocation kit Quote
ep91face Posted January 19, 2009 Posted January 19, 2009 Its nothing like that Glanza_cl its simply the fact that there are small particals of sand/drit/stone in the air. You may think that "stones won't go threw the mesh" but its the fine hard fragments which damage the blades and the housing of your Turbo. Before you tell me I'm wrong, I'm an engineer, I work with centrifugal pump equipment for the gas/oil and water industry. They are pretty much massive turbo's for fluid. The clearances that they are made to are TINY. Its the same with Turbo's on cars.Cal, don't preach bullshit theory's on a board where people need advice. If you are doing it cause it looks "cool" cause you see it on T88'd Supra's and big single turbo Skylines, but these are show cars and never see the road like that.http://www.mkiv.com/techarticles/filters_test/2/ << Have a good read at that.And if that doesn't scare you into running with an air filter try this pic, this is what happens when your a mongo and have no filter on your turbo.can i get you the cheque the cal ? seeing as rubix cube has finished serving you Quote
Callan Posted January 20, 2009 Posted January 20, 2009 not bothered lmao, im meshing mine either way, never run with a filter, if it fucks up get another for £60 odd, ive blocked up my bov too, screamer pipe, meshed, and no bov... lush Quote
Sparky Posted January 20, 2009 Posted January 20, 2009 Sparky you'll never want to fit your dump valve again Fine by me ;) Quote
iamlegend Posted January 22, 2009 Author Posted January 22, 2009 arrrrrgggggghhh this is anoying me :(here is the dumpvalve i gotdo i need any more parts or is that fine pleeeeeeeeeease helpys Quote
Dan Evans Posted January 22, 2009 Posted January 22, 2009 thats fine, just get the pipes connected, then mount it, job done Quote
iamlegend Posted January 22, 2009 Author Posted January 22, 2009 thats fine, just get the pipes connected, then mount it, job donereally?ive been told i need this in the pic (orange outline) Quote
Dan Evans Posted January 22, 2009 Posted January 22, 2009 no you wont mate, that comes with the fitting kit.. i bought mine from an RX7 n was the same as yours, i just mounted it n connected the pipes... mine works and sounds mint.... any probs gimmie a shout Quote
