Hi guys on my last car i had td04 with everything running emanage ultimate with 550cc injectors :p
On my new car it already has an emange blue so what i want to know will this run my tdo4 wih the 550cc injectors aswell as i was once told it would not but im sure i have seen someone with one on theres???
Info please if i can use the blue ill sell my ultimate which is all wired into a harness for plug and play :thumbsup:
the blue should manage it fine, don't see why not the ultimate just has more features so can get an even more refined tune which is why it is used more on the higher power starlet i think? could be wrong
needs mapping to youe setup
if it was mapped for a ct9 at a bar with stock 295cc injectors
then you run a td04 on a abar it will run lean
run it at 0.7-0.8 bar on td04 will be ok for steady driving not worht risking it get it mapped
pm starbus he can map them and not too far from yourself
but yes emanage blue/ulti will run td04 fine with coresct map
i wont be boltng them on till its ready to be remapped it just that i read some where the blue cant hanlde above 50% rise than the stock injector size...
This is why i want to make sure first :thumbsup:
Will i loose any benefitts that i need if i run the blue
