Guest dominodon Posted January 29, 2009 Posted January 29, 2009 What would be the best way to remove a top spoiler on the car if it has sealant to it without damagein it Thanks Quote
ste91 Posted January 29, 2009 Posted January 29, 2009 With one of these:WARNING:- REQUIRES PRECISION AIMING Quote
Guest dominodon Posted January 29, 2009 Posted January 29, 2009 I think if i use that the hole glanza bake been can would be in space ! Quote
Idrees Posted January 29, 2009 Posted January 29, 2009 Replied on TGTT but may aswell add it here for future reference.1) Open the boot and pop off those little black plastic covers in each corner at the top of the tailgate.2) You'll now be able to see two bolts holding the spoiler on. Open both with a deep 10mm socket, a normal socket with an extension might work.3) On the drivers side, try to unplug the brake light. The connector should be near the bolt you just opened.4) Close the boot and push the spoiler upwards. Give it a tug and it should slide off, upwards. Quote
