B19YUL Posted February 8, 2009 Share Posted February 8, 2009 hey guys put a post up about a week or so ago...was driving down the motorway about maybe 90-100mph as was overtaking (wasnt ragging it) pulled back in and came back down to about 75-80mph then as i went to overtake again there was no boost at all and i struggled to get over 80MPH!!!!.(it was raining at the time and there was spray everywere)....have had a good look at the FMIC pipes and connections there was one loose/off so i took the bumper off and went round them all and tightened them all up and checked them all....put the front end back together and took it for a quick spin, but still yet no boost.. i also checked the actuator and the pipe on it but there all still fine and in place. anyone got any other ideas as to what could be causing this? really starting to annoy me ;) could spark plugs cause loss of boost??... Quote Link to post Share on other sites
B19YUL Posted February 8, 2009 Author Share Posted February 8, 2009 Anyone??? Quote Link to post Share on other sites
Dan Evans Posted February 8, 2009 Share Posted February 8, 2009 have you checked the BOV pipe, mine flew off when over taking causing me to have 0 boost! Quote Link to post Share on other sites
B19YUL Posted February 8, 2009 Author Share Posted February 8, 2009 not got a bov just a standard set up but yeah i checked all of them today took them all off and put them all back together and made sure everythin was all tight...but sadly still no boost!! just going to try re-set the ecu see if that helps? Quote Link to post Share on other sites
B19YUL Posted February 8, 2009 Author Share Posted February 8, 2009 just been out and re-set the ecu and nope still no boost !! does anyone know if spark plugs can cause you not to have boost at all?... Quote Link to post Share on other sites
B19YUL Posted February 8, 2009 Author Share Posted February 8, 2009 Anyone at all please?? Quote Link to post Share on other sites
Kennedy Posted February 8, 2009 Share Posted February 8, 2009 I had a problem with mine not boosting properly..looked at the spark plugs and a couple of them had a tiny bit of water on them..dried it all out n that solved my problem..might b worth you looking at?? Quote Link to post Share on other sites
B19YUL Posted February 8, 2009 Author Share Posted February 8, 2009 excellent thank you very much i will be going to halfords tommorow to buy a spark plug socket and a new socket set as some pikey nicked all my tools!! about £350 worth!!! GRRRRR Quote Link to post Share on other sites
GlanzaV33 Posted February 8, 2009 Share Posted February 8, 2009 has it got a miss fire ? Quote Link to post Share on other sites
B19YUL Posted February 8, 2009 Author Share Posted February 8, 2009 it doesnt have a missfire when running but if i have it in neutral and hold the rev's at approx 4k rpm then there is a wee missfire there but not when driving?? there was a missfire a bit ago when on high boost and at low revs but it seemed to disapear? Quote Link to post Share on other sites
rorenapier Posted February 9, 2009 Share Posted February 9, 2009 Did you make sure that there were no rips in the joiners?Over haul the ignition system, just for peace of mind.Check the shaft play in the turbo, if its excessive then this could be the case.If not, then it has to be something simple, like a tear in the vacume lines somewhere.What actuator are you running? Quote Link to post Share on other sites
B19YUL Posted February 9, 2009 Author Share Posted February 9, 2009 Did you make sure that there were no rips in the joiners?Over haul the ignition system, just for peace of mind.Check the shaft play in the turbo, if its excessive then this could be the case.If not, then it has to be something simple, like a tear in the vacume lines somewhere.What actuator are you running? removed all the spark plugs, they were a bit black at the tips so i cleaned them but still no boost!....can really get to all the joiners will get the car jacked up 2moro nyt or wed nite....what you mean overhaul the ignition system>??.how can i get into the turbo to check that??where are the vaccum lines? just running the standard actuator but i have always run standard boost...? cheers Quote Link to post Share on other sites
B19YUL Posted February 9, 2009 Author Share Posted February 9, 2009 anyone?? Quote Link to post Share on other sites
rorenapier Posted February 9, 2009 Share Posted February 9, 2009 Ive replyed to your PM.As for over hauling the ignition system, put new parts in there, Plugs, leads, Dizzy cap and Rotor arm.Its a possibility the standard actuator diagphram is ripped, but im positive you have a burst joiner somwhere.Take them all off, and check for tears. Quote Link to post Share on other sites
B19YUL Posted February 10, 2009 Author Share Posted February 10, 2009 cheers man Quote Link to post Share on other sites
B19YUL Posted February 12, 2009 Author Share Posted February 12, 2009 a little update on the problem, replaced all the spark plugs with new toyota genuine ones and also a new oil filter and new oil, got it all done and still no boost??? its idleing beter but unfortunatly still no boost...found a vacuum hose with a fair sized split in it so taped it up with insulation tape to see if that would maybe help us identify the problem but no!...really staring to worry/annoy me now lol......anyone else have any other ideas as to what the problem could possibly be??????cheers Quote Link to post Share on other sites
Glanza_cl Posted February 12, 2009 Share Posted February 12, 2009 does it come onto boost at all? as if you have the standard actuator like said above the diaphragm inside could have torn, so there is no pressure in the actuator so it isn't doing anything,perhaps try replacing it with another standard or uprated hks, toytuning one.does it make any specific noise when coming onto boost or does it just sound like normal except without the turbo spooling? Quote Link to post Share on other sites
B19YUL Posted February 12, 2009 Author Share Posted February 12, 2009 there is no boost at all.... there is a noise but its not distinctive to anythin there is like a boost leak noise....like a hissing?... Quote Link to post Share on other sites
B19YUL Posted February 12, 2009 Author Share Posted February 12, 2009 also sorry forgot to add in the last post.....dunno about your guys glanza's but when in netural and rev it upto 7k it should 'bounce' off the limiter?? mines does not bounce it was just sitting at 7k and not bouncing? anyone know why this would be? Quote Link to post Share on other sites
Glanza_cl Posted February 12, 2009 Share Posted February 12, 2009 don't no if auto are supposed to bounce off the limiter? not sure if they do...it might be an idea to change the actuator, even if it's just another standard one for the time being to see what happens. Quote Link to post Share on other sites
B19YUL Posted February 12, 2009 Author Share Posted February 12, 2009 yeah it used to bounce off the limiter but it seems to not do it now after this boost problem occured....just put a post up to see if anyone has an actuator they can sell me Quote Link to post Share on other sites
