turner929 Posted February 16, 2009 Posted February 16, 2009 i have got a standard engine and just a big intercooler i need a fcd because it keeps overbossting and i just want it to stop i dont wanna run more than 1bar atm but if i get a fcd will i need fulling mods if so wht? can anyone help please Quote
Glanza_cl Posted February 16, 2009 Posted February 16, 2009 this a warning... running a fcd is not a good thing to do especially on a standard engine.instead get an uprated actuator then turn down the boost... simplethis is the quickest way of recking your engine.get a manifold and exhaust, then a decat, then a rrfpr get it RR at 0.8 that is more then suffice... if you want to run more boost then save and get a piggyback ecu or minimum a fcd AND a SAFC to get a safe map.EDIT: sorry if that souds harsh i just dont want to end up with a blown engine, wait and do it right first time Quote
cam13T Posted February 17, 2009 Posted February 17, 2009 Yes i 2nd that, Manifold and dump and new actuator should be on top of the list. Quote
StarletRick Posted February 17, 2009 Posted February 17, 2009 if you want to restrict boost. get a boost controller. not an FCD.youll end up shagging your engine if you just fit an FCD. the fuel cut is there for a reason... Quote
