benep91 Posted February 28, 2009 Posted February 28, 2009 Safest, cheapest way to around 200bhp?! Quote
Glanza_cl Posted February 28, 2009 Posted February 28, 2009 200bhp is not cheap! i'm trying to reach it and have spent a bomb!it can be done quite cheap, you would need:HybridFMICmanifolddecatexhaustfcd rrfprSAFCuprated fuel pump" clutchthat might reach 200 at a push, but that's without engine going wrong other car costs, maintenance blah blah blahif you can source all second hand then that would cost to muchbut that would not be a very nice car to drive, uprated leads, clutch, good service, short shifter, alloys, suspension, brakes are what makes a car nice to drive.but that list would give good power none the less Quote
Pav Posted February 28, 2009 Posted February 28, 2009 I agree with the above. Its not all about bhp, its how the car drives too!If you want a guaranteed 200 bhp, go for a TD-04. Thats by no means cheap though.I have a hybrid which feels very quick, but the most I've had bhp wise is 182 out of it with 200 ftlbs. An emanage tune will probs squeeze that 200 bhp but thats pushing it. If you want more you need to use more boost which is venturing into the danger zone after 1.1 bar on stock internals.There is no easy way of saying this, but there isnt such a thing as a cheap AND safe way of gaining 200 bhp on the 4e, you have you get your wallet out, plain and simple. Quote
benep91 Posted February 28, 2009 Author Posted February 28, 2009 Cheers for that...i know this all depends on the car etc...but if you had a pretty solid engine to start with and put the boost up to 0.8bar, fmic, decat, manifold and 3" jasma catback what sorta power would u expect? around the 160's? Quote
Glanza_cl Posted March 1, 2009 Posted March 1, 2009 Cheers for that...i know this all depends on the car etc...but if you had a pretty solid engine to start with and put the boost up to 0.8bar, fmic, decat, manifold and 3" jasma catback what sorta power would u expect? around the 160's?yeah if the fueling is ok i would expect around 150-160bhp Quote
mi16chris Posted March 1, 2009 Posted March 1, 2009 tryed and tested u will need good hybrid turbo free flow manifoldde cat good exhaust system good air filter system hks fcd rrfpr fmic uprated actuatoruprated fuel pump would be a good idea and a good clutch toorun 1.1bar of boost u should see 200 pritty easy with a good set up imo no need for a safc Quote
Glanza_cl Posted March 2, 2009 Posted March 2, 2009 tryed and tested u will need good hybrid turbo free flow manifoldde cat good exhaust system good air filter system hks fcd rrfpr fmic uprated actuatoruprated fuel pump would be a good idea and a good clutch toorun 1.1bar of boost u should see 200 pritty easy with a good set up imo no need for a safcpeople tend to run super rich in that set up and potentially can loose power by running to rich i just said a safc as if needed you can trim down the fuel level...but as stated isn't 100%needed just gives you more options for adjustability imoif you want a super 'safe' map just get an emanage or uni chip Quote
starbogt Posted March 2, 2009 Posted March 2, 2009 agreed, i run a similar setup with good results, yes it runs rich at idle but everywhere else the tune is spot on.a piggyback or standalone ecu is a better bet though, and something i will be changing to in the near futureBuy things second hand it worked for me! got TD04 mani fmic etc with radiator 520quid or something all from separate sources. Already had fueling though! but the bargains are when people decide to strip their cars. Got the basics that it would run on and then collected the extra's to get it where it needed to be. Setting it up will cost in excess of 250 quid for just a fuel computer - emanage or equivalent can be double that. hybrid would be an easy option but depends how you want your car to make 200bhp! I prefer the TD04. Quote
benep91 Posted March 2, 2009 Author Posted March 2, 2009 Thanks everyone! decisions decisions..i'd like to go for the TD04 setup but it would have to be from a car being broken...too exsensive otherwise...the hybrid setup is an option though.. Quote
