CRAIG-SR Posted March 1, 2009 Posted March 1, 2009 How easy is it to fit a paseo 5EFE into a N/A Starlet SR?I am thinking of putting a 5EFE into my starlet, just woundering if its a straight swap?Can any point me in the right direction Thanks. Quote
Idrees Posted March 1, 2009 Posted March 1, 2009 I believe it will fit straight in but you will need a couple of extra sensors. One of them is the Throttle Position Sensor iirc. Quote
RobSR Posted March 1, 2009 Posted March 1, 2009 as idrees said, mechanically it will all fit, just a bit of work with the sensors/electrics Quote
CRAIG-SR Posted March 1, 2009 Author Posted March 1, 2009 Take it the looms are different. Can you tell me wot sort of sensors/electrics will need doing? Would the drive shafts need to be swaped? And wot work is involved by turboing the 5efe, Alot of interanal work? Quote
Driver Posted March 1, 2009 Posted March 1, 2009 transplant wont be too dificult as long as you have a good donar with full loom etc and i think shafts will fit standard but dotn quote me on it, turboing wouldnt be difficult either, just low boost on stock internals Quote
Jozinobi Posted March 1, 2009 Posted March 1, 2009 There is quite a bit of info on the 5E NA swap in NA discussions.The work needed for 5EFTE has already been discussed in this very (wrong) section that you have posted in (Alternative Engine Discussions).You must take the time to look through the forum as a lot of it has already been discussed before.We are all here to help but if you do not even make the effort to look, others efforts will have been wasted.Thread now moved to correct section.In future please 'Search' the forum.Thanks. Quote
