starlet virgin Posted March 1, 2009 Share Posted March 1, 2009 hi wanting to change my coolant how easy is it to drop the coolant and change it cheers Quote Link to post Share on other sites
Asad Posted March 1, 2009 Share Posted March 1, 2009 Off with the bottom hose and let it all out, put a water hose in the top of the rad to flush out any gunk.....i`d replace the thermostat while your there cost £10-15, may aswell get a genuine one and saves hastle later on. Also which antifreeze are you using? best one would be toyota red its premixedGood luck Quote Link to post Share on other sites
WallaceGlanza Posted March 1, 2009 Share Posted March 1, 2009 There's a drain plug on the bottom of the radiator so you don't nee to take the hose off, it just unscrews. Quote Link to post Share on other sites
starlet virgin Posted March 2, 2009 Author Share Posted March 2, 2009 There's a drain plug on the bottom of the radiator so you don't nee to take the hose off, it just unscrews.cheers for the help guys Quote Link to post Share on other sites
starlet virgin Posted March 2, 2009 Author Share Posted March 2, 2009 Off with the bottom hose and let it all out, put a water hose in the top of the rad to flush out any gunk.....i`d replace the thermostat while your there cost £10-15, may aswell get a genuine one and saves hastle later on. Also which antifreeze are you using? best one would be toyota red its premixedGood luckcheers mate thats great Quote Link to post Share on other sites
