I have got a Corrola Inlet Manifold , but I guess it make sense to replace the Inlet Manifold Gasket whilst im doing it
Just wanted to know whether I will need the Inlet Manifold Gasket from a corrola or starlet, seeing as its a rolla mani????? :rolleyes:
anyone know how much they cost?
Need to know A.S.A.P so i can order the part and get it on! :harhar:
Many Thanks
Adam
Its the same gasket....mine was stuck to the TB so i left it and put the mani on whereas rickstars was stuck to the mani when we tried to take it off it broke. We could have put a new gasket on but didnt have one so just used instant gasket sealer.
Which Gasket do you mean bud? The engine to mani or mani to throttle. Either way you can reuse both gaskets if they are in a half decent condition. I did when i had one on my n/a. If the throttle one break just use gasket sealer as Asda pointed out.
Bourkey
Rightio cheers guys
Bourkey all that paper has filled my recycling box! :rolleyes:
Cheers anyways :harhar:
For reference though, the throttle body/inlet mani gasket is about £1.50 from Toyota, and the inlet mani/block one is about £8
Thanks Mikey, I will pay them a visit if I end up needing them :D
