nerosis Posted March 8, 2009 Posted March 8, 2009 Where is the adjuster for it?Also, what does the adjuster do??HELP Quote
starlybruiser Posted March 8, 2009 Posted March 8, 2009 Im not sure where the adjuster is on them bov's but it adjusts the spring tension in the bov and determines when it dumps boost, tighten it right up for chatter or have it loose for the normal bov sound, cheers, starlybruiser by the way this is in the wrong section! not for general, should be in tech Quote
paulgtt Posted March 8, 2009 Posted March 8, 2009 See where the vacuum pipe connects to the top of the valve. Next to it theres a nut, loosen that and then you need an allen key to tighten/loosen the adjustment screw. Tighten the nut back up to lock it into position. Quote
nerosis Posted March 8, 2009 Author Posted March 8, 2009 Im not sure where the adjuster is on them bov's but it adjusts the spring tension in the bov and determines when it dumps boost, tighten it right up for chatter or have it loose for the normal bov sound, cheers, starlybruiser by the way this is in the wrong section! not for general, should be in techHaving it fully open or fully closed to get either chatter or BOV sound, will this hurt the engine or anything? Quote
Jozinobi Posted March 8, 2009 Posted March 8, 2009 Please start attempting to post in the right sections.A warning will result soon if you do not start using the site properly.Thank You Quote
