RicoW Posted March 9, 2009 Posted March 9, 2009 Okey, and again trying my best english My turbo is smokey when idling, so the seals would be damaged...I have a replacement ct9A for replacement, but the wastegate has a slight crack, previous owner said it wouldn't affect boost...but is it possible to switch the ct9b (hopefully uncracked) exhaust side with the cracked exhaust side?or do I need to replace the seals when getting them apart?any help or info would be appreciated Rico. Quote
Glanza_cl Posted March 9, 2009 Posted March 9, 2009 i don't know alot about turbo's but the ct9B and A exhaust housing is the same the only difference between the to turbo's is the exhaust blade the B has one more then the A but swapping would be fine afaikif the seals are gone on the ct9A then when swapping over the exhaust housing it would be a good ides to replace the seals to Quote
RicoW Posted March 9, 2009 Author Posted March 9, 2009 the ct9b seals are gone, the ct9a that I have was in fully working order when it was removed from the car.the question for now is: when I want to swap the exhaust housing, do I need to replace the seals?and does anybody have any pictures of how it looks like?so I know what it looks like when going to swap them.thnx for the info Quote
