Ok, my glanza has now done 75,000 miles, and im going to service it.
What should i be looking to swap out in this service
Obviously things like oil,filter,brake pads i know of.
Anything i probably wouldnt do that i should?
well im going to be servicing my car in the next week or so.
i'v ordered oil,oil filter,fuel filter,iridium spark plugs,new lambda sensor,brake pads all round and new rear discs,also changing my air filter to the front if that counts ;)
i'v checked my distributor cap,rotor arm and leads there all ok.
doing this before the mot so shes running right.
Consider changing timing belt, fuel filter.
Then just check all your suspension bushes and bearings and all your fluids.
Brake Fluid, Power steering fluid, check the coolant, tyre pressures.
all the parts and service intervals are listed here and can be obtained by sam
clicky
