kevink Posted April 2, 2009 Posted April 2, 2009 http://www.ukstarletclub.com/forums/index....l=screamer+pipe Quote
WallaceGlanza Posted April 2, 2009 Posted April 2, 2009 A screamer pipe is basically a direct exhaust from the wastegate of the turbo.With an internal wastegate setup - as on the stock ct9 turbo, this invloves a dual exit or separated downpipe which at one side joins to the exhaust like normal from the turbo exhaust housing and at the wastegate side has a short open pipe which vents to atmosphere thus making the "screaming" noise when the wastegate opens. A separator plate is needed in the turbo between the wastegate and turbine exhaust wheel to stop the exhaust gases simply leaking straight out of the screamer pipe.People's opinions differ on how a screamer pipe sounds on the stock ct9 but most agree they sound good on larger turbos and especially with an external wastegate setup. Quote
zacontour Posted June 11, 2009 Posted June 11, 2009 I cant find glanza v on many insurers like elephant. shall i insure it as a Gt turbo or what??i heard of some people ringing up and saying its a gt turbo bet the face lift???plz help Quote
Maz90 Posted June 11, 2009 Posted June 11, 2009 Only sound good on a big turbo with an external wastegate in my opinion. Quote
