I have been reading on www.Japanparts.com about Cusco strut bars for the EP9.
And i found these 2:
And there was some text attached, that says this.
The Carbon one:
Type CB/ FRONT
40mm Diameter carbon shaft strut bar. Shaft: Carbon fiber Section shape: Round. Plate: Steel in titanium color. Only for Turbo models.
And the other one:
Type AS/ FRONT
Aluminum shaft strut bar. Shaft: Aluminum. Section shape: round. Plate: Steel painted in blue. Bolt-on type. Exchange genuine bar. Impossible to equip on NA.
And I was thinking, how come it cant be mounted in a N/A starlet, Whats the difference?
I thought that the Turbo (Glanza) and the N/A Starlet, are the same (almost).
Well I definitely seen the AS mounted to a few SR's before, there is no reason why the CB and AS won't fit out n/a starlets and I am sure some people can confirm that who have had them before or still do. Its like saying the oem glanza brace is for glanza only!
I don't think they got their facts right...
There is also the OS version which is a thicker bar than the AS.
Have fun checking this page out!
Cusco Strut Braces
Peace Out :lol:
Joz
Front bars match on N/A and Turbo models, on EP71, EP82 and EP91. But the back bar from the glanza doesn't fit to a N/A car! I have tryed! The Glanza Chassie is higher at the back...
Good luck!
Good luck!
<{POST_SNAPBACK}>
the rear ones do fit mate as i had one on my n/a and same for the front!!!
This means that this one will also fit?
Cusco Rear Lower Strut Bar - Starlet
Item number 1875
Cusco rear lower strut bar. Suitable for Toyota Starlet EP81 and EP92. Image for illustration.
Price : £ 75.00 (plus postage)
Item number 1875
<{POST_SNAPBACK}>
Watch out Raffi, our cars is not the same as a glanza. The 2 bolts that hold the damper at the top is opposed from ours.
Thats good enough, but no one of those is original Toyota Strut Bar. After the weekend I can get a pic of the originals, as I have them both...
Is it the same strut bar at front and back?
  scutch0 said:
no, it wont, i think the glanzas have a raised part of the floor for the centre of the brace to attach to.
<{POST_SNAPBACK}>
Yeah the glanzas floor is raised. But the Cusco strut bar does not fit at the rear.
