Russleh Posted April 10, 2009 Posted April 10, 2009 as above. got a small leak and looks a bit like its coming from the gearbox. anyone got any ideas or had similar ??? Quote
Starlet__SR Posted April 10, 2009 Posted April 10, 2009 as above. got a small leak and looks a bit like its coming from the gearbox. anyone got any ideas or had similar ???Pic????? Quote
Russleh Posted April 10, 2009 Author Posted April 10, 2009 a bit dark just now but ill take one tomorrow or whenever i can bud. praying its just seals or somethin lol Quote
Tintin_SR Posted April 10, 2009 Posted April 10, 2009 a bit dark just now but ill take one tomorrow or whenever i can bud. praying its just seals or somethin lolonly thing it can bee in crank seal of drive shafts seal give it a sniff if its normal its engine side if it smells like cat wee then its box side Quote
Russleh Posted April 11, 2009 Author Posted April 11, 2009 have given it a sniff and it smells normal so im guessin its the engine side. ill post up a pic in a while anyway. Thanks bud. Quote
Russleh Posted April 11, 2009 Author Posted April 11, 2009 pics. if ya can make them out its basically of the end of the gearbox where it joins the block. couldnt fit the jack under the car so i couldnt get any decent pics lol. Quote
4efte_ryan Posted April 11, 2009 Posted April 11, 2009 thats your rear main oil seal may aswell do the clutch at the same time Quote
Russleh Posted April 12, 2009 Author Posted April 12, 2009 cheers bud. ill need to wait till i have some money if im gonna do the clutch also tho lol. Quote
4efte_ryan Posted April 12, 2009 Posted April 12, 2009 yea i no it sounds pointless atm to change the clutch but it will be worth it in the long run Quote
Russleh Posted April 12, 2009 Author Posted April 12, 2009 just so when i come to do it. u can just drop the gearbox out eh ? dont wanna have to take the engine out although it would be good practice for when i do a swap Quote
4efte_ryan Posted April 12, 2009 Posted April 12, 2009 yes mate piece of piss jus take shafts out disconnect every thing on box (if taking starter motor right off disconnect battery) support, engine take off mounts and finally undo bell housing bolts and box will came out easy peasy bud Quote
