Sparky Posted April 17, 2009 Share Posted April 17, 2009 Hey guys whats the best way to go about this?How does the cable detach from the gearbox side and whats the best way to remove it?Cheers Lewis Quote Link to post Share on other sites
RobSR Posted April 17, 2009 Share Posted April 17, 2009 you unscrew it from the box...and actually changing the thing is a twat.. Quote Link to post Share on other sites
Sparky Posted April 17, 2009 Author Share Posted April 17, 2009 Yea I had a look doesnt look like fun!So you just unscrew the cable anticlockwise until it comes off? Quote Link to post Share on other sites
RobSR Posted April 17, 2009 Share Posted April 17, 2009 yea thats the easy bit lol, its feeding it through the interior thats the fun bit Quote Link to post Share on other sites
Sparky Posted April 17, 2009 Author Share Posted April 17, 2009 lol does the cable come out of the bit that you unscrew, so you can feed it down through the dash or do you feed it up through the bulkhead? Quote Link to post Share on other sites
AlexGTAdv Posted April 17, 2009 Share Posted April 17, 2009 Unscrew it from the gearbox, then take the speedo out and disconnect the cable from the back of it and feed the cable through the bulk head into the engine bay. Then reverse for refitting, quite easy really. Quote Link to post Share on other sites
RicoW Posted April 17, 2009 Share Posted April 17, 2009 u can also tape the new speedo cable on to the old one, so when u pull the old one out.u pull the new one directly into place. Quote Link to post Share on other sites
Sparky Posted April 17, 2009 Author Share Posted April 17, 2009 Good tip there will give that a go Quote Link to post Share on other sites
MadMan Posted April 22, 2009 Share Posted April 22, 2009 u can also tape the new speedo cable on to the old one, so when u pull the old one out.u pull the new one directly into place.defo do it this way the speedo must be the most annoying thing on the car the space you get is nowt]got two cablees here if u still need one buddy Quote Link to post Share on other sites
