nerosis Posted April 18, 2009 Share Posted April 18, 2009 Ive just fitted my Air Filter relocator from TT and it sounds a treat.Basically, when i give it some beans in 2nd gear, it cuts out at 50mph, where before i put the air filter on it was going to almost 70mph.Is this fuel cut? the car just dies at 50mph and i have to change gear.What is this. Help? Quote Link to post Share on other sites
Sparky Posted April 18, 2009 Share Posted April 18, 2009 Its boost creep mateBecause of the less restriction you hit fuel cut before you would normallyIdeally you need a boost controller and port the wastegate on the turbo now Quote Link to post Share on other sites
nerosis Posted April 18, 2009 Author Share Posted April 18, 2009 Its boost creep mateBecause of the less restriction you hit fuel cut before you would normallyIdeally you need a boost controller and port the wastegate on the turbo nowIve ordered a BCC and a RRFPR to fit which come monday.Will these parts sort the problem?Is the car alryt to drive as long as i dont rag it? ( i dont wanna break it ) Quote Link to post Share on other sites
Sparky Posted April 18, 2009 Share Posted April 18, 2009 You will need to get the fuelling tuned with that set up.Still wont stop the creep, just get rid of the fuel cut.If you have an adjustable actuator turn it down a bit, if you dont have one then it should hold boost a bit better when you get one.Could cause serious engine damage running over a bar of boost on the stock exhaust manifold and other stock parts Quote Link to post Share on other sites
nerosis Posted April 18, 2009 Author Share Posted April 18, 2009 You will need to get the fuelling tuned with that set up.Still wont stop the creep, just get rid of the fuel cut.If you have an adjustable actuator turn it down a bit, if you dont have one then it should hold boost a bit better when you get one.Could cause serious engine damage running over a bar of boost on the stock exhaust manifold and other stock partsIve got a TT actuator but it isnt fitted as my boost gauge wont be here until monday.What can i do until monday then to not "Kill" my car?I really dont wanna kill it from just a air filter Quote Link to post Share on other sites
Glanza_cl Posted April 18, 2009 Share Posted April 18, 2009 just dont boot it mate. drive slow lol Quote Link to post Share on other sites
nerosis Posted April 18, 2009 Author Share Posted April 18, 2009 just dont boot it mate. drive slow lolWhat if im cruising along at 60 - 70mph, will this be bad for the car atm? Quote Link to post Share on other sites
Glanza_cl Posted April 18, 2009 Share Posted April 18, 2009 no if you dont hit fuel cut then it isnt going to cause any harm, more annoyance then anything as if you do boot it a bit you will soon hit fuel cut.just take it easy Quote Link to post Share on other sites
nerosis Posted April 18, 2009 Author Share Posted April 18, 2009 no if you dont hit fuel cut then it isnt going to cause any harm, more annoyance then anything as if you do boot it a bit you will soon hit fuel cut.just take it easySo it is fuel cut then?My new BCC and RRFPr and boost gauge should be here monday, then i'll be fitting all that along with my TT actuator. Will this sort the problem and let me use full boost again?So as long as i dont hit fuel cut it wont be harming my engine at all?? Quote Link to post Share on other sites
nerosis Posted April 18, 2009 Author Share Posted April 18, 2009 The engine management light popped on for about 3 secs then went off and got all power back.Basically, when i get my BCC, RRFPR, actuator and boost gauge on and fitted on Monday wont everything be fine?I just really dont wanna kill it lol Quote Link to post Share on other sites
Sparky Posted April 18, 2009 Share Posted April 18, 2009 Jeez do you read the posts or what?It wont be fine unless when you get your BCC and RRFPR your getting it set up on the dyno properly aswell? Quote Link to post Share on other sites
montanajr Posted April 18, 2009 Share Posted April 18, 2009 The engine management light popped on for about 3 secs then went off and got all power back.Basically, when i get my BCC, RRFPR, actuator and boost gauge on and fitted on Monday wont everything be fine?I just really dont wanna kill it lolEeekkk! Fitting your BCS and FPR will make everything fine....if by fine you mean not fine! You can use the BCC to remove fuel cut and then the FPR to increase fuelling to compensate for the extra boost. If you want to stop creep, look here: http://www.ukstarletclub.com/forums/index....&article=20 Quote Link to post Share on other sites
nerosis Posted April 18, 2009 Author Share Posted April 18, 2009 Eeekkk! Fitting your BCS and FPR will make everything fine....if by fine you mean not fine! You can use the BCC to remove fuel cut and then the FPR to increase fuelling to compensate for the extra boost. If you want to stop creep, look here: http://www.ukstarletclub.com/forums/index....&article=20So it will still fuel cut when ive got my fpr, bcc and actuator fitted, even if i turn down my actuator?Can i no just turn the actuator down so that i dont hit fuel cut? Quote Link to post Share on other sites
andy.i Posted April 18, 2009 Share Posted April 18, 2009 its fuel cutting as the boost is creeping to .85barjust turn the actuator down so it doesnt creep as much, use a boost gauge to checkthen go to a RR and get the rest put on and set up Quote Link to post Share on other sites
Sparky Posted April 18, 2009 Share Posted April 18, 2009 No it wont cut with your BOOST CUT CONTROLLER on!! Quote Link to post Share on other sites
RobSR Posted April 19, 2009 Share Posted April 19, 2009 if you fit your bcc your not going to hit fuel cut. however you will start over boosting and start melting things if your still on the stock mani. . if you just want to run under fuel cut don't bother fitting the bcc and reg. just fit the adjustable actuator. set it a bit longer than standard... and then see if its helped. its trial and error tbh. if your still having problems after that (good chance you will) either port the Wastegate or fit a restrictor ring in the exhaust and then raise the boost up to .85bar with an EBC. .hope that helps Quote Link to post Share on other sites
