aye a was gona go that way wanted to be sure first tho!
Foliatec Caliper and Engine Paint/Laquor heat resistant up to 750 degrees cheap on ebay comes in range of colours its a 2part mix and comes with prep spray most expensive in halfords but e-bay its around £25. one kit will do both callipers and engine i done mine will post pic shortly mate
i used normal spray paint, white base coat, then 4-5 layers of blue then 4-5 layers of lacquer, never had any probs, and its only £2ish a tin anyway
i used engine paint good for temps up to 150Celcius.
the real heat paints that resist up to 650Celsius have to be heated to about 100C to harden and for that reason aren't the best choice. Normal spray paint shold do the job to tbh. it is all about the amount of layers and time you take to do it propperly.
