Tha Dragon Posted May 17, 2009 Posted May 17, 2009 Hi there guy'sI just finished with some upgrades on my Pocket Rocket,Just installed FPR and a Turbonetics Manual Boost Controller.I got a problem guy's a couple of days ago i went to start my car but it took allot to start it,i need to keep holding the key allot for it to start then i took a look and i saw my Boost Controller had turned and i thought that's why it took allot to start but now it's doing it again,battery is fine,they told me to check or replace the fuel-filter.Could 1 of you guy's please help me with my problem?Thanks in advanceTha Dragon Quote
interloper393 Posted May 17, 2009 Posted May 17, 2009 i would replace or at least clean your plugs, then remove and clean inspect the distributer cap, then check the leads.. but i reckon its one of the above :surrender: Quote
Tha Dragon Posted May 17, 2009 Author Posted May 17, 2009 i would replace or at least clean your plugs, then remove and clean inspect the distributer cap, then check the leads.. but i reckon its one of the above :surrender:Ok Thanks i'll try that and come back soon if it still remains on doing it. Quote
Tha Dragon Posted May 21, 2009 Author Posted May 21, 2009 Hi Guy's i did some research on the problem that i have but did not get nothing yet and i have been through eveything but nothing is was wondering if it's the FPR that's giving me trouble cause i used a tutorial i found on the forum but i didn't know if i could apply it or not but when i installed the FPR i put the pressure on 45 psi could 1 of you guy's tell me if i'm doing it right or not?And 1 more thing i insalled my manual boost controller but when i raise the boost it will only go to -10 won't go higher do 1 of you guy's know what the problem is there?Thanks in advanceTha Dragon Quote
Maz90 Posted May 21, 2009 Posted May 21, 2009 Think it may be the plugs or the dizzy as interlooper said.My mate had a simaliar problem and it turned out too be the dizzy Quote
project82 Posted May 21, 2009 Posted May 21, 2009 does it ever make a clicking noise when trying to start?if so starter motor just like some people said make sure plugs sre clean and make sure they are sparking make sure its getting fuel Quote
Guest Enzo Posted May 21, 2009 Posted May 21, 2009 had the same problem with the mbc so chucked it in the bin,do you have an adjustable actuater ? Quote
Tha Dragon Posted May 22, 2009 Author Posted May 22, 2009 had the same problem with the mbc so chucked it in the bin,do you have an adjustable actuater ?No i have a stock actuator,gonna get me a HKS Actuator next month,cause at the end of this month i'll be waiting for my Exhaust Mani and Downpipe. Quote
Tha Dragon Posted May 27, 2009 Author Posted May 27, 2009 Hi there guy'sDid you guy's ever notice when you put your ignition to on you see the "ABS" light and then after a few seconds or so it go's of and you hear the "ABS" give out a sound or something?I was checking that out and i notice that my car was doing that sound when i got it but after i installed the FPR and the MBC, it gives out the sound sometimes and sometimes not?What do guy's think would be the problem?thanks in advanceTha Dragon Quote
Guest Enzo Posted May 27, 2009 Posted May 27, 2009 its the abs pump priming, it only does this somethimes but mostly Quote
Tha Dragon Posted May 27, 2009 Author Posted May 27, 2009 its the abs pump priming, it only does this somethimes but mostlyI thought it has to do it every time or something or am i worrying to much? Quote
Guest Enzo Posted May 27, 2009 Posted May 27, 2009 it sounds like your worrying too much mate but then again if you did notice it after fitting the pressure reg i dont see how that would affect the abs pump Quote
Tha Dragon Posted May 27, 2009 Author Posted May 27, 2009 it sounds like your worrying too much mate but then again if you did notice it after fitting the pressure reg i dont see how that would affect the abs pumpok,and 1 more thing Enzo.Do you think it would be a good idea to install a Supra Fuel Pump on my car? Quote
Guest Enzo Posted May 28, 2009 Posted May 28, 2009 i dont know your spec or setup so could not really advisethere is nothing wrong with the standard pump, if you have a monty big turbo then yea by all means go ahead if its to hand Quote
Tha Dragon Posted May 28, 2009 Author Posted May 28, 2009 i dont know your spec or setup so could not really advisethere is nothing wrong with the standard pump, if you have a monty big turbo then yea by all means go ahead if its to handMy Setup:Racing AirfilterFPR put on 45 PSIMBCRacing ClutchNext month i'm about to go custom exhaust mani and decat,stock actuator. Quote
Guest Enzo Posted May 28, 2009 Posted May 28, 2009 if i were you id put the fpr down to standard psi if it is not already , and rip the mbc out.invest in an actuater and dremel the restiction in runner number three and gut the cat.all cheap and easy mods, you dont need a fpr unless your running past fualcut boost why dont you start a build thred mate Quote
Tha Dragon Posted May 28, 2009 Author Posted May 28, 2009 if i were you id put the fpr down to standard psi if it is not already , and rip the mbc out.invest in an actuater and dremel the restiction in runner number three and gut the cat.all cheap and easy mods, you dont need a fpr unless your running past fualcut boost why dont you start a build thred mate Cause they i already asked on the forum and they gave me a 200HP Setup and i'm working on that,that's why i already have those on. Quote
Tha Dragon Posted March 28, 2010 Author Posted March 28, 2010 Hi there guy'sMy problem has got a bit bigger now cause i went driving a couple of weeks ago and i went pass fuel cut and now my car doesn't want to start.I got me some TRD Leads,changed my coil to an MSD Coil, i need to change my dizzy cap and rotor but they seem fine. these upgrades were after fuel cut.Now i got all those but nothing my car wont budge,try to start it but doesn't go on.Want's to start but doesn't go on PLEASE NEED SOME ADVICE ASAP.It's drift weekend and i really want to go to that show!!!!Best RegardsTha Dragon Quote
Tha Dragon Posted March 28, 2010 Author Posted March 28, 2010 I had installed a supra fuel pump but yesterday i was checking so i put my own fuel pump back in it but it still doesn't want to star.It's giving me a real headache cause i always need to ask somebody for a lift to get to work and all that.NEED THE HELP AND ADVICE AND INFO PLEASE!!!!BEst regardsTha DragonFuel pump? Quote
5T4R7ET N/A Posted March 28, 2010 Posted March 28, 2010 i think that FPR may be giving you the problem mate, since it started to happen after this mod? i am right?put standard one back on and see if it makes any differenceworth a shot! Quote
Tha Dragon Posted March 29, 2010 Author Posted March 29, 2010 Ok i'll give it a try,but tomorrow there's a machanic passing by and i'll let him check what the problem is and i'll let you know, but when i installed the FPR it didn't give me no trouble. Every Mechanic i asked is telling me the same thing they say it looks like that my car isn't getting enough spark or something.But i take a look se and i'll let you guy's know.THE MORE ADVICE AND HELP THE MERRY.Best regardsTha Dragoni think that FPR may be giving you the problem mate, since it started to happen after this mod? i am right?put standard one back on and see if it makes any differenceworth a shot! Quote
