SpeedFreak Posted May 27, 2009 Posted May 27, 2009 My light has blown thats behind the Speedo, and I really need to get it changed. Does any body know what type of bulb this is, and where is best to get them from?Also, how easy/hard is it to pull out the clocks to fit it? Is it simply plug in and it works?ThanksStace Quote
vit Posted June 9, 2009 Posted June 9, 2009 hi,it's the same one u used in wing corner light or no plate bulb don't know the name for it ..and for the clock its is its plugs in but a bit technical to take out without taking the steering wheel..and to remove the speedo cable.can be done without removing steering or cover understeering if you know how to do it..and have a very small hand.. Quote
