mel Posted May 28, 2009 Share Posted May 28, 2009 How much ? & where can you get a recon turbo CT9 for a glanza V think mine is on its way out ! Quote Link to post Share on other sites
Maz90 Posted May 28, 2009 Share Posted May 28, 2009 For the extra power just save up for a hybrid Quote Link to post Share on other sites
andy.i Posted May 29, 2009 Share Posted May 29, 2009 cheaper binning it and getting a 2nd hand one Quote Link to post Share on other sites
Glanza_cl Posted May 29, 2009 Share Posted May 29, 2009 as above, get a second hand one or spend the money it would cost to rebuild and get a hybrid... not necessarily that you want more power but over all it will be a better turbo and obviously if you decide to up the power you already have the means to do so. Quote Link to post Share on other sites
mel Posted May 29, 2009 Author Share Posted May 29, 2009 so its ok to put a hybrid on if everything is standard on my engine? Quote Link to post Share on other sites
molovin Posted June 23, 2009 Share Posted June 23, 2009 I need to no the same thing aswell. Gutted the Tong turbo's have gone up in price Quote Link to post Share on other sites
bucketep91 Posted June 23, 2009 Share Posted June 23, 2009 molovin said: I need to no the same thing aswell. Gutted the Tong turbo's have gone up in pricei wouldnt think it would be a problem if you where running standard boost, not to sure though Quote Link to post Share on other sites
Glanza-Love Posted June 23, 2009 Share Posted June 23, 2009 Its perfectly safe to run a hybrid turbo as long you run no more than 0.9bar as this is not pushing the engine or turbo Quote Link to post Share on other sites
molovin Posted June 23, 2009 Share Posted June 23, 2009 Glanza-love got your pm thanks. Contemplating waiting until 5pm to confirm if ill have your tubby as i may get a Hybrid waiting for confirmation from the courts today regarding the ban and what not. If i dont get banned for long i will get a hybrid if i do ill get your off you if you dont mind wiaitng for a little while? Quote Link to post Share on other sites
Steve GT Posted June 27, 2009 Share Posted June 27, 2009 mel said: so its ok to put a hybrid on if everything is standard on my engine?yer will be fine. course like any turbo car if you seriously ride on the limiter everywhere you'll eventually send the turbo into hyperspace. but running a hybrid tubby on standard internals should be fine if you look after it Quote Link to post Share on other sites
WallaceGlanza Posted June 27, 2009 Share Posted June 27, 2009 No its not a good idea to just chuck a hybrid on a standard engine especially if running higher boost (stock boost levels might be ok as they run a little rich as standard), you'll need to get the fuelling checked and most likely tweaked to cater for the extra air the hybrid will be putting into the engine.People have chucked hybrids on in the past without doing this and then asked why their engine has blown. Quote Link to post Share on other sites
Glanza_cl Posted June 27, 2009 Share Posted June 27, 2009 WallaceGlanza said: No its not a good idea to just chuck a hybrid on a standard engine especially if running higher boost (stock boost levels might be ok as they run a little rich as standard), you'll need to get the fuelling checked and most likely tweaked to cater for the extra air the hybrid will be putting into the engine.People have chucked hybrids on in the past without doing this and then asked why their engine has blown.^^^ Indeed, i put a hybrid on with only fairly basic stage one mods and found the car to quite undriveable compared to the standard ct9, the car wasn't as responsive as the turbo wasnt running in it's efficiency zone and with the enlarged inlet on the turbo the air flow was alot greater meaning on some cars it can make them run lean.I am still running the hybrid on stock internals on the stock ecu, but i have had to uprate to a Sard regulator and proper HKS evc6 ebc to control the boost and the fueling, (still under fuel cut)it will be fine but definitely watch the cars afr's when running the likes of a Tong or other hybrids on the stock ecu. Quote Link to post Share on other sites
