This is the exact problem WEPR had with the first batch of hybrid turbos.
Was rather annoying, but it pulled througn it after a bit
what the video is saying is it aint lined propperly basicly the prop is hitting the wall ever so slighltly... and pulling through... not realy its probably cut away at the inside of the turbo for it to actualy spool propperly..
also in badnes means theres a gap when the turbo is spooling not so good as that could cause some problems especialy holding compression/boost ... i assume would also eventualy kill the turbo via the shaft!
I can assure you it isnt the comp wheel hitting the inside of the turbine.
If it were it wouldnt be there now, the comp wheel would be abbliterated.
After 1.5 years of running it, it is all to do with the flow of the turbo suited to the engine size, ie the turbo is to big.
