prangers Posted June 16, 2006 Share Posted June 16, 2006 has anyone got a walk through on filling up the gear box oil. what oil to use and how much to put in cheers Quote Link to post Share on other sites
scutch0 Posted June 17, 2006 Share Posted June 17, 2006 there are two big bolts on the box;one on the top, and one on the side (at the front)take them both out, fill from the top hole and when its at the right level it should start coming out of the side hole.put the bolts back in.easy peasy.Rich Quote Link to post Share on other sites
klyfax Posted June 17, 2006 Share Posted June 17, 2006 Are you running with a LSD? Quote Link to post Share on other sites
starletboy Posted June 18, 2006 Share Posted June 18, 2006 uuuhhh never heard of fillin the box up that way before there is one at the front on the side yes its a 24mm bolt thats the where you fill it up from the drain plug is at the bottom of the box at the back next to the n/s driveshaft and again thats a 24mm bolt if uve been fillin it up from the very top like you said i think you are gonna have some problems!!!!!!!!!!!!!!!!! Quote Link to post Share on other sites
prangers Posted June 18, 2006 Author Share Posted June 18, 2006 ok ive filled it up from the top. what kinda problems am i looking at. the nut that came out of it had a dip stick kinda thingy on it and was covered in an oil of some kind ???????? Quote Link to post Share on other sites
scutch0 Posted June 19, 2006 Share Posted June 19, 2006 well i topped mine up about 15,000 miles ago, and have since had it topped up by my mechanic, an he said it was ok?ive had no problems. Quote Link to post Share on other sites
prangers Posted June 19, 2006 Author Share Posted June 19, 2006 did you use the bolt at the very top of the gear box which is very visible as you look straight down onto the box ????? hopefully i used that one too then. it did have a long bolt with a kinda dip stick thingy at the end of it lol Quote Link to post Share on other sites
scutch0 Posted June 19, 2006 Share Posted June 19, 2006 yeah, pretty sure that was it... cant really remember lol Quote Link to post Share on other sites
