hi can any one help i have just got an toms ecu just need to know if i need any thing else as a few people have said i need a high temp spark plug and leads,fpr and upgraded fuel pump i want to run 1 bar on standard internals and stock ct9 my car spec at the moment is standard boost car has blitz ner spec ,stainless Mani ,blitz air filler and bov ,rx7 top mount intercooler ,1.3 rad cap ,boost controller o and it will also will have an adjustable actuator soon had to order another one as i ordered one for :) toytunning :p
You don't need a FPR or fuel pump you will be fine on standard parts.
If you don't have one already - grab yourself a decat. (You didn't mention it).
You might want to cancel the actuator with TT and give TM-Developments a shout! ToyTuning are going down the pan and people are having nothing but trouble with them!
Standard FPR and pump is fine for a bar boost mate, just get NGK Iridium plugs (Grade 7) and some new leads and a decat as Ste said :)
cheers guys i have cancaled toytunning part i will order decat just had new egine and new plug were just fittted i will check what was used thanks again
