Handbrake Light.
the little light that comes on when you use your handbrake comes on when i use my brakes. used to be just hard braking but not its more or less whenever i push the pedal. any ideas. sounds like a dodgy wire or somethin but i thought id check n see what people say :). cheers
Russell
the little light that comes on when you use your handbrake comes on when i use my brakes. used to be just hard braking but not its more or less whenever i push the pedal. any ideas. sounds like a dodgy wire or somethin but i thought id check n see what people say :) . cheers
Russell
that light can also mean your brake fluid level is low and it might be going under min when you press the pedal
  • 1 year later...
