GT Phayer Posted June 21, 2009 Posted June 21, 2009 i just went to drive my starlet for the first time and the cooling fan does not work even when thet gauge is near the red and the heaters + rad + both hoses are boiling hot any ideas ???? and i have the air con switch bridged from when i removed the air con and wen i unbridge it the fan runs so think the fan is ok Quote
nicwan8 Posted June 21, 2009 Posted June 21, 2009 i just went to drive my starlet for the first time and the cooling fan does not work even when thet gauge is near the red and the heaters + rad + both hoses are boiling hot any ideas ???? and i have the air con switch bridged from when i removed the air con and wen i unbridge it the fan runs so think the fan is okFaulty thermostat not opening could be the problem Quote
GT Phayer Posted June 21, 2009 Author Posted June 21, 2009 but the radiator gets hot and the heaters n things are hwould they still do that if the thermostat was faulty cheers mate Quote
nicwan8 Posted June 21, 2009 Posted June 21, 2009 but the radiator gets hot and the heaters n things are hwould they still do that if the thermostat was faulty cheers mateReally hard to say. SorryEven if the fan is "broken", happen to me before, the water pump should be pumping the water around the radiator system.So, I would change the cheaper option 1st; thermostat then faulty wiring of the fan then finally water pump if it's failingIf u r not mechanical minded, get it looked at asap Quote
vit Posted June 21, 2009 Posted June 21, 2009 hey ,if you know what you are doing and can find the thermotat switch ,remove the plug and brigde the two terminal ,if it work your wirring is find and it will be the thermostat switch,but if does not will be some wiring problem,check allthe connection might be lose connection. hope that help .thermostat switch for fan and the thermostat is two diferrent thing. Quote
Asad Posted June 21, 2009 Posted June 21, 2009 is the bottom rad hose "cooler" than the top one?for the coolant temp sensor ^ follow the bottom hose to the block its the green coloured one also the thermostat is held on by 2x 10mm nuts its literally takes 5 min to take out and replace. Quote
GT Phayer Posted June 21, 2009 Author Posted June 21, 2009 i bridged it and turned the ignition on and nuthing happen and no they are both reli hot and the rad is to and the heaters in the car Quote
